Question Question abaout a case plz Help
Fashion13
Hello guys i want to buy a water cooling processor for my cpu and iam gonna buy Arctic Liquid Freezer II 240 A-RGB but i dont know if it fits on my case can someone help me?
Cpu : AMD Ryzen 7 5700X 3.4GHz
Case : Corsair Carbide Spec 0-3
More information needed:
What other components will be installed?
Measurements?
Product Specs?
Links?
Details matter?
My case : https://www.laptopsdirect.co.uk/cor...d-tower-gaming-case-cc-9011052-ww/version.asp
My Build :
CPU: AMD Ryzen 7 5700x Eight-Core Processor
GPU: Sapphire Radeon RX 6750XT 12GB Nitro+
Motherboard: MSI X370 Gaming Pro Carbon (MS-7A32)
SSD M2: Samsung 970 Evo Plus 500GB
SSD: Kingston SSDNow UV400 240GB
HDD: Western Digital Red 1TB
RAM: Kingston HyperX Fury DDR4-2400 1x16 GB
Power Supply: Corsair RMx Series 750X
Case: Corsair Carbide Spec-03 LED
water cooling : https://www.arctic.de/en/Liquid-Freezer-II-240-A-RGB/ACFRE00093A
What cooler are you now using?
Are you having a cooling issue with it?
Cooling should not be a big problem in a gaming environment where only a handful of cores will be fully utilized.
Are you looking for RGB "bling"?
Is liquid cooling "cool"?
A 240 aio has about the same cooling capacity as a twin tower air cooler.
Noctua maintains a list of suitable air coolers; here is the list for a 5700X:
https://ncc.noctua.at/cpus/model/AMD-Ryzen-7-5700X-1603
Many of the best are too tall for your case which allows 150mm.
The NH-D12L at 145mm will fit:
https://noctua.at/en/nh-d12l/specification
And... did you know that aio coolers do not last forever?
In time, the mechanical pump fails or gets clogged.
Air will enter through the tubes requiring a replacement.
Think 5 years.
Think 5 years.
Hello now i have this : https://www.amazon.com/Stealth-Connector-Aluminum-Heatsink-3-93-Inch/dp/B07MFMFL7R
i want to change it becouse i have 51°C idle and 80-90°C gaming
i didnt know about aio coolers
That cooler is a top down cooler that is not as efficient as a tower type cooler.
Tower type directs heated air out the back of the case.
Your case is a good one for air cooling.
The NH-D12L is outstanding, but at $90, it may be too expensive for you:
https://www.amazon.com/Noctua-NH-D1...f9fd311ba3fe3cb48d112e7ec69eda8c&gad_source=1
Look for a tower type cooler with a max height that is 150mm tall or less and which supports the AM4 socket.
Reactions: Paperdoc
