GPUs in general can handle some pretty high temps, although it can start throttling at the higher temps. If you've got semi- decent case cooling, depending on your ambient temps, maxed out you will probably be averaging out around 70C-75C. You don't really need to worry about anything under 85C or so, but it will run much better if you can configure your GPU fan profile and case cooling to keep it under 70C.
