Question about choosing components when building a Gaming PC.
Sep 5, 2014
7
I am thinking of building a Gaming PC and i am wondering if some components work better when matched with other components. I am not talking about compatibility issues. For example would an i5 4670 work better with a GTX 760 or with a R9 270x, and also would this CPU perform better with a certain compatible MoBo or would just any compatible Mobo perform the same. I hope i made my question a bit easier to understand. Also, is there anything i can do to increase the "lifespan" of the PC i am going to create? I am asking this because i keep hearing that pre-built brand PCs last longer than the custom made ones and are sure to perform well because they were tested for a long time.
A few ideas how to expand the life span of components:
1) keep them cool
2) look on big tech sites (like newegg) for reviews of the specific components. And I mean the end users` reviews. Look at the statistics. If you have a lot of reviews with only one egg in comparison with 5 eggs, then you have a problem and you can move to the next one.
I prefer just typing in what I`m looking for, than select only the 5 eggs/stars items, so the lower ones go away.
This will allow you to have the most reliable components, therefore to ensure the least probability of having problems. You can`t just have NO problem at all, that would be an utopia 😛
indy
1) keep them cool
indy
Make sure you read those reviews though. Some people post reviews on there and are either really ignorant or just acting it. Like I have seen reviews before on graphics cards with one egg which said stuff like "Didn't improve the video quality of my movies. Complete waste of time."
or people who bought a ZX7 motherboard meant for overclocking and bout a non-overclocking CPU and gave it one egg cause they couldn't overclock.
Thanks. I will keep those things you said in mind.
