D
Deleted member 2720853
Guest
I'm buying a be quiet! Pure Base 500DX case and want to replace the built-in fans with two 140mm High Speed (1600rpm) PWM intakes at the front, and I plan to keep the built-in exhaust fan on the rear which always runs at 1000rpm. Is it okay if my rear exhaust is 1000rpm, my two intakes run at about 1400-1600 while gaming, and to have no exhausts on top? Or do I need a higher speed exhaust fan too?
