T Taki_Shog May 21, 2019 2 0 10 May 21, 2019 #1 hi will a D-Sub monitor work with a PC that supports VGA + DVI-D
Lutfij Titan Moderator Oct 7, 2009 59,162 6,165 178,440 May 21, 2019 #2 List the GPU you're working with and the monitor you want to work with. Upvote 0 Downvote
T Taki_Shog May 21, 2019 2 0 10 May 21, 2019 #3 Lutfij said: List the GPU you're working with and the monitor you want to work with. Click to expand... I got vega 8 amd and the monitor is a Phillips Upvote 0 Downvote
