Question Question about NZXT 510i case and Arctic Liquid Freezer II
CAAA
19
https://www.reddit.com/r/NZXT/comments/dprwm8 View: https://www.reddit.com/r/NZXT/comments/dprwm8/can_anyone_confirm_nzxt_h510_atx_mid_tower_case/
So someone mentions that the AIO cooler can only fit if the mounting bracket is put in between the radiator and the fans at the front of the case , my question is does this effect performance or anything? Like do the fans have to be attached to the radiator or does the mounting bracket being "sandwiched" in between lower efficiency and yeah let me know please!
Radiator SupportFront: 2x 140 or 2x 120mm with Pull
Means that 240 and 280mm radiators can fit in front, that's fairly standard for cases of that size.
"AIO cooler can only fit if the mounting bracket is put in between the radiator and the fans at the front of the case". that's also standard way of mounting radiator and it's fans, fan screws are long enough to pass thru fan and thin metal of bracket. That doesn't detract anything from cooling. Just make sure that fans are oriented so they blow air thru radiator.
