Question Question about OC temps
Aug 15, 2019
9
Hi,
So I overclock my CPU and put it under a stress test and it reached temps of 96-97C. The CPU is an i7-9700k, MB is Gigabyte z370p d3, cooler is a Noctua NH-D15. Is this temp normal under a stress test(I used Prime95)?
I've OC'ed it to 5Ghz, voltage at 1.340, LLC set to turbo. Is something wrong wrong with the fan?
Here is a SS of the stats : https://ibb.co/SwjBYfp
Thanks.
Take that LLC off turbo before you burn something up.
That is too high to be running with just an air cooler.
Keep it on the medium setting.
I've disabled the OC for now, in gaming I had stable temps of max 70C, only under Prime95 I reached those temps. Will have to find a stable solution before I try to OC again. Thanks for the info.
How's the case cooling?
Multi-core Enhancement disabled?
case cooling is decent, nothing amazing. I got 2 extra fans on the case. Multi-core Enhancement is enabled.
Someone told that 1.34v is actually not that much for 5Ghz, especially considering the fact that the default Vcore is 1.3V. Maybe I should increase it to 1.35 or 1.36 ?
