Hey!!
I bought 4 of these Logisys Stove Fans, but didn't realise that the LEDs were only on one side, and thus they wouldnt be of much use at the back of the case as when set up for the air flowing out (2 pull in air from the front, and 2 push air out at the back), the LEDs end up inside the case and thus aren't that pretty 😀
So, I was wondering if by just switching the wires, would I be able to make the fans rotate in the reverse direction? Would this cause any effect on the PSU? If Im not mistaken, of the two wires (the red and the black), one is the ground, and the other actually provides the power to the fan, thus would reversing them actually mess up my PSU over time?
I know this is a case by case basis depending on the type of fan, and thus I am posting pics of it below:
The 2 wires I'm hoping of switching are the small red and black ones (the ones shown in the 3rd pic going directly to the fan). I'm thinking of just cutting them open at the middle (length), and then soldering the two to the opposite ones, and then covering it up with electric tape. The fans take an input of 12V (pretty basic).
Would this be advisable? Also I know that the fans performance might slow down a little bit, but I just analyzed them, and they pretty much look the same from both sides.
Thanks!
Thanks!
