So I'm slowly building my PC, already bought the case (meshify 2 compact rgb), psu, ssd, aio etc. But I have a question regarding controlling rgb using hardware button on the case. Let's say I want to have all my rgb stuff (case, aio, ram and maybe motherboard and gpu and a led strip) controlled with a single button on the case, is it poasible? For example I want Northern Lights colors on case, and the rest of the components. Is that possible, or will I have to install some software for controlling lights from within Windows?
I guess ram, gpu and probably motherboard rgb will need to have a dedicated software installed on pc, right? Since they aren't directly connected to the case controller? For case and aio (both from fractal) that won't be a problem since they i can daisy chain them. but what about the rest? Or should I build my PC around connecting every rgb component to the motherboard? Hopefully it's clear enough what I wrote. Thanks in advance.
The reason I'm asking is I'd rather avoid installing crap ton of rgb software. My previous board (msi) needed Msi center installed to control rgb lights. It was quite buggy and couldn't detect some of the components. So if I could control lights from a single hardware button that would be awesome...
