Archived from groups: rec.games.frp.dnd (
More info?)
laszlo_spamhole@freemail.hu wrote:
> Bradd W. Szonye wrote:
> > laszlo_spamhole@freemail.hu <laszlo_spamhole@freemail.hu> wrote:
> > > Chris The Wizard wrote:
> > >> So I'm going to be joining an epic level game and I was thinking about
> > >> tossing a few gold to a ring of invisibility for the little AC bonus in
> > >> combat, but I realized it said it was invisibilty as the spell, so does
> > >> that mean the second I make an attack I would become visible?
> > > That is correct, you'd have to reactivate it again (a Standard action).
> > > Also, since it's CL 3, it wears off (and must be reactivated) every 3
> > > minutes.
> > I'm not sure about the duration. Because of the way item pricing works,
> > duration has no effect on cost, and most worn items seem like they're
> > assumed to work continuously.
> Nope, it's unambiguous. Here are the relevant bits from the SRD:
> "Usually, a ring's ability is activated by a command word (a standard
> action that does not provoke attacks of opportunity) or it works
> continually."
> "By activating this simple silver ring, the wearer can benefit from
> invisibility, as the spell."
Yep, I noticed this in my last campain with the ring of blinking. One
of the PCs had it 'on' all the time for encounters. Then I noticed the
activation bit.
Still it doesn't take that much to reactivate it every so often before
it runs out, and remain invisible. Just means you can't sleep
invisible.
- Justisaur
