Question Question about Seagate PCB replacement/repair. Not powering up.
Mar 20, 2025
8
This is an older drive. I stopped getting power a while ago. I don't recall ever hearing any clicking like you'd expect with total drive failure. When I plugged it in recently no sound at all but the drive got very hot and there was a burning smell. Now I get nothing when I plug it in. And there appears ti be a burnt area on the PCB. All this tells me it's likely I could recover the data by replacing the PCB or removing the diode on the existing PCB.
I'm trying to get two questions answered.
1. I believe my drive has been over-volted and I know from a separate thread that the diode can be removed. Can someone point out what diode I am supposed to remove.
2. If this doesn't work I've identified the correct board for $44 but I've seen in two different forums that the BIOS chip needs to be transferred from the old board to the new board. I'm not clear on which is the BIOS chip. Pic is available here:
Any help greatly appreciated!
Miles
Your picture didn't parse through. Host your image on a site akin to Imgur and then pass on a link for us to see.
Perhaps this video;
View: https://youtu.be/QfrjCip1WtI
will help you get closer to the BIOS chip's location.
IMHO, since you're a novice and if the data is valuable, I'd locate a professional data recovery specialist and not tamper with the drive.
I'm not exactly a novice. This is an easy fix I think. View: https://imgur.com/a/trNDFfg
Ok. Removed and cleaned 12V diode.
Can you show me what needs to be soldered? I am going off this post where you successfully helped someone ( https://forums.tomshardware.com/threads/seagate-hard-drives-not-powering-up.3497494/ ) but your old photos are no longer available.
Here's the updated of mine: View: https://imgur.com/a/nrejWp5
Thanks for your help with this!
_______________________________________________
I can't see the pics from your post from the old thread:
In your second drive the 12V TVS diode is marked with "KVP + 06A". I would remove the diode and clean up the charred mess with a toothbrush and isopropyl alcohol. Then solder a wire between the last 3 pins of the SATA power connector and the striped end of the diode ("v" on PCB).
Something like this:
In the case of your first drive, the 12V TVS diode has an "LF" logo. Remove it.
There are two zero-ohm resistors near the SATA power connector. Flow a blob of solder over them.
Your PCB is similar to this one:
That's a shock sensor. A drive may have 1 or 3 of these. One is used for general shock detection, while rotational vibration sensing requires two more. The latter is optional for enterprise models. Nothing to worry about.
Hard drive shock sensors:
https://www.hddoracle.com/viewtopic.php?p=19489#p19489
So regarding the 12 TVS diode. Do i need to solder on a replacement diode? I seem to think that at some point I read I could just solder a metal connection between the two ends to bridge it.
No, you don't need to replace the diode as long as you are sure that your PSU and its cabling are good, and if you don't care about continued protection.
Replacing the diode with a wire would be like placing a spanner between the terminals of your car's battery. DON'T DO IT.
Reactions: MC33
