[SOLVED] Question for lian li o11 mini owners
LORYT699
Commendable
Apr 6, 2022
190
6
1,595
I was just figuring out if an ATX psu can fit in that case.
Can someone give me the size of the space avaliable?
More accurate that you can pls, I d like also know the space on the main fan space, the one near the mobo(no upper and no bottom), cause I see some peaple are putting there the psu(is ugly but worthy).
Thanks
from here,
from here,
Thanks but no thanks,we are in a nD space, It can t be enogh just 1D XD, I need the w d h, not only 1 direction.
btw thanks for thise but I nedd the accurate size at mm of heac direction
I found from lianli cad file, the psu clearance is the atx one but he have to be tall mac 68(70 is actual ok)
You can mount it in the frontal fan space it will be ok anyway
