Question Question How are my HDD's extended SMART Results?
Apr 27, 2024
Hello,
I'm hearing noises from my 12 TB used industrial HDD and I was recommended to do an extended SMART results, but I can't understand it.
Could someone help me with it ?
https://pastebin.com/C7hJ3erZ
Code:
smartctl 7.4 2023-08-01 r5530 [x86_64-w64-mingw32-w10-22H2] (sf-7.4-1)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     HUH721212ALE601
Serial Number:    AAGSHZWH
LU WWN Device Id: 5 000cca 278cab095
Firmware Version: LEGL0002
User Capacity:    12,000,138,625,024 bytes [12.0 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database 7.3/5528
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Apr 27 02:04:27 2024 CDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     128 (minimum power consumption without standby)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2], Master PW ID: 0xfffd
Wt Cache Reorder: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (   87) seconds.
capabilities:              (0x5b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
SCT capabilities:            (0x003d)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
  2 Throughput_Performance  P-S---   132   132   054    -    96
  3 Spin_Up_Time            POS---   195   195   024    -    263 (Average 413)
  4 Start_Stop_Count        -O--C-   100   100   000    -    102
  5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
  7 Seek_Error_Rate         PO-R--   100   100   067    -    0
  8 Seek_Time_Performance   P-S---   140   140   020    -    15
  9 Power_On_Hours          -O--C-   096   096   000    -    32294
 10 Spin_Retry_Count        PO--C-   100   100   060    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    29
 22 Unknown_Attribute       PO---K   100   100   025    -    100
 45 Unknown_Attribute       PO---K   100   100   001    -    1095233372415
192 Power-Off_Retract_Count -O--CK   100   100   000    -    522
193 Load_Cycle_Count        -O--C-   100   100   000    -    522
194 Temperature_Celsius     -O----   157   157   000    -    38 (Min/Max 22/56)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    0
198 Offline_Uncorrectable   ---R--   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
231 Temperature_Celsius     -O--CK   100   100   000    -    0
241 Total_LBAs_Written      -O--C-   100   100   000    -    5469375908642
242 Total_LBAs_Read         -O--C-   100   100   000    -    4389007666844
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O    255  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   5501  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80       GPL     R/W    688  Host vendor specific log
0x81-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xb2       GPL     VS     688  Device vendor specific log
0xc8       GPL     VS      12  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Selective offline   Completed without error       00%     32294         -
# 2  Selective offline   Interrupted (host reset)      60%     32272         -
# 3  Selective offline   Aborted by host               90%     32267         -
# 4  Extended offline    Aborted by host               90%     32267         -
# 5  Extended offline    Aborted by host               90%     32266         -
# 6  Extended offline    Interrupted (host reset)      90%     32265         -
# 7  Extended offline    Aborted by host               90%     32265         -
# 8  Extended offline    Aborted by host               90%     32264         -
# 9  Short offline       Completed without error       00%     32252         -
#10  Short offline       Completed without error       00%     32252         -
#11  Vendor (0x70)       Completed without error       00%     31810         -
#12  Vendor (0x71)       Completed without error       00%     31809         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA      MAX_LBA  CURRENT_TEST_STATUS
    1        0  23437770751  Not_testing
    2        0            0  Not_testing
    3        0            0  Not_testing
    4        0            0  Not_testing
    5        0            0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
Device State:                        Active (0)
Current Temperature:                    38 Celsius
Power Cycle Min/Max Temperature:     36/51 Celsius
Lifetime    Min/Max Temperature:     22/56 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (18)
Index    Estimated Time   Temperature Celsius
  19    2024-04-26 23:57    44  *************************
 ...    ..(102 skipped).    ..  *************************
 122    2024-04-27 01:40    44  *************************
 123    2024-04-27 01:41    43  ************************
 124    2024-04-27 01:42    43  ************************
 125    2024-04-27 01:43    42  ***********************
 126    2024-04-27 01:44    42  ***********************
 127    2024-04-27 01:45    42  ***********************
   0    2024-04-27 01:46    41  **********************
 ...    ..(  4 skipped).    ..  **********************
   5    2024-04-27 01:51    41  **********************
   6    2024-04-27 01:52    40  *********************
 ...    ..(  2 skipped).    ..  *********************
   9    2024-04-27 01:55    40  *********************
  10    2024-04-27 01:56    39  ********************
  13    2024-04-27 01:59    39  ********************
  14    2024-04-27 02:00    38  *******************
  17    2024-04-27 02:03    38  *******************
  18    2024-04-27 02:04    44  *************************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              29  ---  Lifetime Power-On Resets
0x01  0x010  4           32294  ---  Power-on Hours
0x01  0x018  6   5469375908642  ---  Logical Sectors Written
0x01  0x020  6      6257436117  ---  Number of Write Commands
0x01  0x028  6   4389007666852  ---  Logical Sectors Read
0x01  0x030  6      5623002698  ---  Number of Read Commands
0x01  0x038  6    116260750750  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           32280  ---  Spindle Motor Power-on Hours
0x03  0x010  4           32280  ---  Head Flying Hours
0x03  0x018  4             522  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4            8860  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              38  ---  Current Temperature
0x05  0x010  1              45  N--  Average Short Term Temperature
0x05  0x018  1              43  N--  Average Long Term Temperature
0x05  0x020  1              56  ---  Highest Temperature
0x05  0x028  1              22  ---  Lowest Temperature
0x05  0x030  1              55  N--  Highest Average Short Term Temperature
0x05  0x038  1              23  N--  Lowest Average Short Term Temperature
0x05  0x040  1              54  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             149  ---  Number of Hardware Resets
0x06  0x010  4             100  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2        65535+ Transition from drive PhyRdy to drive PhyNRdy
0x000a  2           10  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
Code:
Health is good.
Zero relocated and zero pending sectors.
Can you record those noises?
You can share the recording with vocaroo.
