Question on Case details chart and fitting radiator
MDXX
1,405
Not really sure how to read this right. But on the details sheet it has 2 columns. 120mm and 140mm radiator
Under the 120mm it says up to 360 for front. And for the 140mm it says up to 280 for the front. What exactly does this mean?
Parts involved are Corsairs H100i V2 and the Enthoo Evolv. Pretty sure the radiator is 240mm
In the Phanteks specs sheets for liquid cooling, the 120mm column refers to radiators having such width but varied lengths based on number of 120mm fans (e.g., 120mm (1-fan), 240mm (2-fan), 360mm (3-fan), 480mm (4-fan)...). On the other hand, the 140mm column refers to radiators having such width but varied lengths based on number of 140mm fans (e.g., 140mm (1-fan), 280mm (2-fan), 420mm (3-fan)...).
In your case, the Corsair H100i v2 is indeed a "240mm" radiator, which means it uses two 120mm fans. But note that the actual dimension of the radiator is not exactly 240mm in length. The 240mm simply means nominal length - not actual dimensional length. This is important as some case specifically states the actual length of...
In your case, the Corsair H100i v2 is indeed a "240mm" radiator, which means it uses two 120mm fans. But note that the actual dimension of the radiator is not exactly 240mm in length. The 240mm simply means nominal length - not actual dimensional length. This is important as some case specifically states the actual length of radiators that can fit in their mounting locations.
For the Enthoo Evolv being fitted with the Corsair H100i v2, you won't have any problems with such.
In fact you have two options to choose from where you can mount the 240mm radiator in the Evolv case: Top (Supports up to 360) or Front (Supports up to 360).
Sample build of a Corsair H100i v2 fitted on top of a Phanteks Evolv case: https://pcpartpicker.com/b/Hd9J7P
Sample build of a Corsair H100i v2 fitted at the front of a Phanteks Evolv case: https://pcpartpicker.com/b/ZRV6Mp
