Ok, I recently ordered a CX 750 Corsair PSU for my first build. I have tinkered with components before, but this will be my first build with all raw components and case. The main purpose will be for gaming, and learning the processes for overclocking and tweaking the system to get the desired result. (Whatever that may be for the task at hand.) I ordered the CX after doing some research and seeing some positive reviews of the psu, but after the order had shipped I began seeing other threads with information I missed. Namely bad capacitors, limited lifespan, and the 80 bronze meaning it will supply 80 percent of 750 at load. There has been conflicted info, so I'm here for clarification.
I plan to overclock to some degree, but I'm wondering on how much power extra clocks consume on cpu and gpu, and on the gpu recommendations of 750w minimum. Is there overhead factored in?
Specs are:
Corsair 500r Carbide Edition
AMD 8350 Vishera
ASRock Killer Fatality 990x
Corsair CX 750w
1tb HDD @ 7200
Asus 5.25 optical
Asus R9 270 2gb
Cooler Master Hyper 212
G. Skill Sniper X Series 8gb SDRAM @ 1866
I plan in the future to upgrade to either XFX DD Black R9 280x or HIS Ice Q X2 R9 280x. (Both rated at 750w minimum)
Any tips or clarification would be appreciated.
Specs are:
AMD 8350 Vishera
Corsair CX 750w
1tb HDD @ 7200
Asus 5.25 optical
Asus R9 270 2gb
