G'day guys,
I'm looking to switch over to a custom loop water cooling solution for my PC, but have absolutely no idea what to do or how to do it. I live in Australia where it gets in excess of 45 degrees Celsius during summertime and my GPUs and CPU just aren't handling it very well.
I'm currently running an i7 4790k with a h100i for the cpu, and two Gigabyte 980Ti Windforce cards in SLI that have about 1.5cms between the top and bottom card. The fans on the bottom card have completely shattered and fallen apart, most likely due to heat and exhaustion as they're running at 100% all of the time. As a result, I've had to remove the bottom card as it currently has absolutely no means of cooling itself whatsoever. The fans on the h100i are also EXTREMELY noisy when run at performance mode, which they need to be on 24/7 otherwise the cpu idles at 60 degrees and goes up to 100 under load. Remember, the ambient temperature in my room is often as high as 40 degrees Celsius.
The case that I'm using is a Coolermaster mid size case that you can see at this link here - https://www.mwave.com.au/product/cooler-master-cm690-iii-midtower-atx-case-with-window-ab55227
I've been looking at EKWB's website but I'm always put off at how daunting it is, and all the videos I find on YouTube cover the application of the block to the card, and stop there. I've got no idea what actually needs to be done inside of the case. I'm assuming I need some kind of custom loop that flows between the cpu and the two gpus and that I'll probably need to do away with the h100i? That's fine if so.
If somebody could please provide me with a very clear and concise response, telling me the most efficient and cost effective solution, I would be immensely grateful. Please let me know the products/parts I'd need to order and how I'd go about doing it.
I'm completely clueless about water cooling, but have put together actual computers on several occasions with no issues whatsoever. This is just very unfamiliar territory for me.
Thanks for your help
- Cheru
- Cheru
