Question Question Regarding Wired Network and Wireless Mesh
ngaihou
13
I have a question regarding the feasibility of a combo setup between wired connections as well as wired mesh. I would also appreciate any hardware recommendations.
My intended setup can be found in this Network Diagram.
The solid lines indicate a wired connection while the dotted lines are wireless.
Any feedback is greatly appreciated.
ngaihou
13
Yes, due to the fact that I only have ethernet cables for those 2 spots.
The third "wireless router" is for the network on a separate floor. Maybe a "wireless access point" would be a better description?
Somebody go into business with me, I have this idea using using low power laser beams with with transmitters mounted high up the ceiling and mirrors on corners, and BAM, cover your whole house for high bandwidth and no messing with wall holes and make ur landlord mad. :)
