Question Question with power phase control
Mr.AntiSocial
9
so I opened AI suite 3 for the first time and I see that I have power phase control set to extreme as I'm not sure if its good for me or not I wanted to ask my CPU is the i7-4770 and idk which option is best for me I had this pc for about 2 years and I think in that time span it was set on that so idk if I'm late in asking this
If the system is working well then leave things alone.
AKA "If it ain't broke then don't fix it".
I would want some very strong evidence showing real benefits of AI no matter what service or product is being touted.
You can find out more about your PC's power setting by using the "powercfg" command in DOS.
FYI:
https://learn.microsoft.com/en-us/w...ice-experiences/powercfg-command-line-options
https://www.thewindowsclub.com/most-useful-commands-for-powercfg-command-line
Again, just look and maybe print out for future reference.
Then just leave alone until there is a specific problem.
I had an ASUS board for my 4770k. If I recall the AI Tweaker or whatever it was called wasn't too bad when it came to overclocking settings. A little more aggressive than it needed to be, but I am sure that how close it gets to correct very CPU dependent.
My particular 4770k wasn't very good, so I only ever got it up to 4.3Ghz at around 1.29 volts. Anything at or below 1.3 volts for the CPU core is fine for daily use.
So as long as that extreme VRM profile isn't letting LLC or something push the CPU to the limit, should be fine. Run a few benchmarks while keeping an eye on the core voltages with something like hardware monitor 64.
