Hi everyone.
I have a build that I hope to get soon and I have some questions about my case airflow.
Here are my specs:
MB: Asus TUF GAMING X570-PLUS
CPU: AMD Ryzen 9 3900x
AIO: NZXT Kraken X62
GPU: Gigabyte RTX 2080 SUPER 8GB GAMING OC
Case: NZXT H700i
I know the H700i comes with 3 front intake fans (all 120mm) and 1 exhaust fan on the back (140mm),
I am hoping to top mount the X62 and use both of its 140mm fans as exhausts.
Will that create negative pressure inside the case?
If so, how should I change my fan configuration and/or fan speeds to make it maybe positive pressured?
Also here are the fan specs:
Three fans in the front are:
Aer F120 (Case Version)
Speed: 1200 + 200 RPM
Airflow: 50.42 CFM
The back fan is:
Aer F140 (Case Version)
Speed: 1,000 + 200 RPM
Airflow: 68.95 CFM
The AIO's fans are:
Aer P140
Speed: 500~1,800 +/- 300RPM
Here are my specs:
Case: NZXT H700i
Airflow: 50.42 CFM
The back fan is:
Airflow: 68.95 CFM
The AIO's fans are:
Aer P140
