My motherboard has an option which allows me to select my CPU speed. Additionally, I have GPU Tweak (also came with my MOBO instillation disk). I would like to OC, but I don't know if I even need it or if it is worth the risks. To be honest, I don't really even know the risks.
I have a ton of fans, my temps (CPU, GPU, MOBO) tend to stay below 40C even when gaming, so I feel like heat won't be an issue...but I dunno :/
My CPU and GPU almost never go above 70% usage, but I do have frame rate issues (Which is weird, because, to someone who is not very knowledgeable about this stuff, it would seem like they should be close to maxed out before I get laggy.
I would really like to learn about OC, so please feel free to get down into the details.
My questions are as follows:
1) I often have frame rate issues in games such as Arma 3; my friends with lower-end PCs and slower connections don't have the same problems...could overclocking my CPU and GPU fix this?
2) In Minecraft I experience a constant (almost unnoticeable) blurry, pixelated, screen-tearing. Its really annoying...could OC fix this?
3)Now to the more important stuff. How safe is overclocking the CPU? The GPU? In terms of "chance", how likely is it that something will get fried/overheat?
4)What effect will it have on the lifetime of my CPU and GPU?
5)How "unstable" could it make things? I feel confident about using my BIOS "automatic" OC capabilities, since its as simple as selecting the speed I want and it does the rest of the work. Same for GPU Tweak. However, I really don't know much about this stuff, so, once again, I would like to ask your your opinion.
My CPU runs 3.9Mhz base; My GPU runs 1111Mhz
Here is my build:
OS: Windows 8.1
CPU: Intel® Core™ i7-4770K Processor 3.90 GHz
MOBO: Asus Maximus VI Formula Motherboard
GPU: Asus Geforce GTX770-DC2OC-2GD5
Memory: 16 GB Gskill Trident X
CPU Cooler: Cooler Master Nepton 280L
SSD: Samsung 840 Pro Series 2.5-Inch 256 GB SATA 6GB/s
HDD: WD Blue 1 TB : 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache
ODD: Asus 24x DVD-RW
Case: CoolerMaster HAF X Blue
Here is my build:
OS: Windows 8.1
