Question Questions on M2 drives for Z790 Wifi 7 Motherboard
Jul 26, 2024
I just purchased the Player Three Prime and it has the Z790 wifi 7 motherboard. It has 3 M2 slots and the first 2 are filled. I would like to add to the last slot.
Specs:
CPU: Intel i9-14900KF
GPU: NVIDIA® GeForce RTX™ 4090
Memory: 128GB (4 x 32GB) DDR5 6000 Mhz
Storage: 1TB NVMe M.2 SSD
Cooler: NZXT Kraken 280
Power: 1000W Gold
Notes on M2 slots:
Intel® Core™ Processors (14th & 13th & 12th Gen)
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 mode)
M.2_2 slot (Key M), type 2242/2260/2280 (supports PCIe 4.0 x4 mode)
Intel® Z790 Chipset:
M.2_3 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
I am thinking a 8T card and was looking at: Corsair MP600 PRO XT 8TB NVMe M.2 SSD
Some questions:
1) This seems compatible with my board — yes? Although it seems bigger given the heat spreader design (Note: The cooling system is: 7 fans and the NZXT Kraken 280 cooler already)
2) Is this a good choice or something better?
I could also use some install instructions. I have the manual and will review videos, but if you have power tip form doing this before, I would be grateful.
Many thanks!
As long as there's plenty of clearance for the heatsink then there's no reason it shouldn't work. There's really nothing particularly special when it comes to installing them just don't overtighten the screw as they tend to be tiny and annoying.
thanks!
