Hi 😍
I want to overclock my E8400 to 4GHz but i have never tried to overclock before. I%u2019ve read everything there is to read but i%u2019m not confident enough to preform an actual overclock (i have some questions and i want you to comment my procedure).
I will follow the guide in the Forum and i am not concerned about the less imortant stuff such as setting my PCI Express Frequency to 100 MHz or disable Max CPUID value limit and so on. I want to focus on the actual overclock.
Keep in mind that i will overclock my E8400 to 4 ghz.
At First i go into the BIOS and set my DRAM Frequency to the double of my overclock, that would be 890 mhz since i am going to raise my FSB to 445 (Question 1: would i then achieve a ratio of 1:1?).
Secondly i raise my FSB by steps of 5 untill my computer crash (sounds odd but that is what i can conclude). Then i would reset my BIOS and reboot my computer because i can conclude that my system is too unstable to run.
At this point i would raise my CPU voltage because i%u2019ve reached the loft at which my CPU can overclock at the current voltage.
Then i would reboot my computer to see if it%u2019s stable. If that is the case i%u2019ll repeat the first step and raise my FSB by a margin of 5 each time untill i%u2019ve reached my overclock.
I would then verify that my system is stable by using Ohrtos or programs alike (running for 2hours).
Finally i would go back to the BIOS and tweak my Vcore so that it fits perfectly. I end my overclock my running Ohrtos for 12 hours straight and hopefully i will not get any errors.
Questions:
1. If i set my DRAM Frequency to the double of my overclock, that would be 890 mhz since i am going to raise my FSB to 445. Would i then achieve a ratio of 1:1?
2. How much do i have to raise my Core Voltage when my computer begins to crash/gets unstable?
3. Should i use software to check the stability of my system each time i raise my FSB by 5? (alternative would be to wait untill my computer crashes, then reset BIOS and start over)
4. I am really worried about configurating my ram. I do not know if i have to run it at the native speed of 5-5-5-15 or at 4-4-4-12. I know that the ratio needs to be 1:1 but i don%u2019t know how to achieve this and i don%u2019t know if it%u2019s necessary. The full specifics for my ram is listed below.
Crucial Ballistix 2 GB ( 2 x 1 GB )
DIMM 240-pin - DDR II
1066 MHz ( PC2-8500 )
CL5
2.2 V
5. Do i need to increase the voltage of any other component? (motherboard, ram). If this is the case would you care to adventure into this act?
6. This is the overclock i want to achieve: http://i28.tinypic.com/2mrijar.jpg . Now, i know that each chip is different but could i just take those numbers in the picture and plug it into the BIOS?
If not, would it be a good guideline to overclock my CPU? By looking at the picture i know the boundaries and where i approximately need to hit Vcore.
Best regards!
PS: Excuse my poor language i am a Dane.
Questions:
CL5
2.2 V
Best regards!
