Hello!
I'm after some advice regarding this build. It is my first build and the goal was to stay within a budget of £800. I am currently about £150 over budget.
I was unable to find the case I want to use on this site - it is the Cougar QBX Mini ITX Case.
This is what I have specked out so far:
PCPartPicker part list: https://uk.pcpartpicker.com/list/zwJ9QZ
Price breakdown by merchant: https://uk.pcpartpicker.com/list/zwJ9QZ/by_merchant/
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor (£247.99 @ Aria PC)
Motherboard: MSI - B450I GAMING PLUS AC Mini ITX AM4 Motherboard (£123.40 @ Alza)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-2666 Memory (£210.20 @ Amazon UK)
Storage: Samsung - 970 Evo 250 GB M.2-2280 Solid State Drive (£64.99 @ Amazon UK)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive (£54.79 @ Aria PC)
Video Card: EVGA - GeForce GTX 1060 6GB 6 GB SC GAMING Video Card (£202.46 @ Scan.co.uk)
Power Supply: Corsair - VS 550 W 80+ Certified ATX Power Supply.
The purpose of this build is (in order of importance):
Productivity - office based tasks, research etc (I'm currently a student)
Photo editing (recreational)
Video editing (recreational)
Very occasional gaming
My questions related to this build are:
Is the Ryzen 7 2700 overkill, would I be fine with a Ryzen 5 2600x or an Intel i5 9600k?
Is it worth getting 32gb of RAM for the price (£210) or is it better to set up with 16gb for half the cost and reconsider upgrading in a few years?
Is the power supply adequate - or should I consider upgrading it? - the reason I have chosen this for now is that the case will only allow a PSU with 14cm in length to be mounted.
Thanks for any advice or feedback you can offer me!
