S strokebow Dec 12, 2024 2 0 10 Dec 12, 2024 #1 Quick q. I'm installing pny Nvidia rtx 5000 Ada 32gb. The cable it comes with plugs in to my GPU and splits in to 2x 8 pin connectors for the PSU. Do I need to connect the PSU to both of these or just one of them? Thanks in advance
rgd1101 Don't Moderator Nov 7, 2011 74,861 4,244 176,290 Dec 12, 2024 #2 both. they didn't have them just for show Reactions: strokebow Upvote 0 Downvote
logainofhades Titan Moderator Apr 27, 2009 39,367 4,629 143,290 Dec 12, 2024 #3 Do you have link for said card? I believe those only have a single 8 pin connection. Upvote 0 Downvote
S strokebow Dec 12, 2024 2 0 10 Dec 12, 2024 #4 rgd1101 said: both. they didn't have them just for show Click to expand... Thanks I needed that reassurance My confidence is low. Upvote 0 Downvote
faalin Illustrious Feb 22, 2012 6,443 540 41,740 Dec 12, 2024 #5 If your power supply has the 12+4 pin cable you can use that, if not then you will need to plug both 8 pins into the Y cable that came with the card. Do not use 2 8 pins off the same cable, you need two dedicated 8 pins coming from the PSU. Upvote 0 Downvote
