Question Quietest 3 pin 120mm fan with CFM close to 50
Phanteks, Noctua's, Be Quiet's, if you can still find them then, Scythe Gentle Typhoon AP's. You might want to also factor in that audio can be perceived differently by different folks. Some people can hear the ticking of the motor in a fan, some people can't even hear the pitch of the fan as it cuts through air.
Are you looking for fans to use in a case(airflow) or on a radiator(cooler)?
Thank you for your reply. I am looking for a fan to cool a CPU radiator.
I would rather spend more but get something that will last.
Please let me know what would you recommend.
Thank you
Hi Again!
CPU cooler is Corsair CWCH70. It is watercooling radiator.
After reading some reviews, I decided to go with two Artic P12 PWM PST in black, please see link below.
Link
Let me know if that's a good choice.
Thank you again.
Ildar
