I'm looking for something as quiet as Noiseblocker NB-eLoop® Series140mm (5.7 dBA), ideally with comparable airflow 73.6 m³/43.34 CFM, which has 4 pin (PWM) fan (so that I can turn it off completely when browsing internet) AND 120mm mounting (can be 140mm fan with 120mm mounting or just a 120mm fan).
Priorities are:
1) 120mm mounting (only way it will fit)
2) quiet (below 10dBA)
3) good airflow
4) 4 pin (PWM)
I wouldn't be surprised if it turned out to be impossible to fulfil my needs, but still I'm not losing hope.
If only the Noiseblocker had a version with 120mm mounting then I could forgo the PWM (I know they have 120mm fans, but they are both louder and have worse airflow).
EDIT:
I forgot to mention that if it is a PWM fan then obviously only the minimum noise should be below 10dBA.
Priorities are:
3) good airflow
4) 4 pin (PWM)
EDIT:
