R driver 3, just got one of these, might come in hand
it is a cable that will let you connect h/d to your pc via usb and also dvd/cd roms, so no need for caddy/enclosure my question is as iv only just got it the only thing i could test it on is a dvd/cd rom it worked fine the dvd rom showed up in 'my computer' now a mate of mine has got a laptop but the o/s wont load and he was wondering if it was his h/d or something else so i took the r driver 3 over to connect his laptop h/d to his desktop to see if it worked the problem is it didn't show up in 'my computer' his pc showed it 'found new hardware' and the 'safely remove hardware' listed it and also it was listed in 'device manager' under 'disk drives' i even went to 'add new hardware' but it was listed there as working properly but i cant find it in 'my computer' so that we could explore it, now i am not 100% certain but i think any device connected to this cable must be set to 'master' i don't know if this applies to h/d i did look at what looked like pins on the h/d but there was no jumper or anything to tell you which set was for master, i did connect the h/d and powered it up using the lead that came with this cable before plugging it in to the desktop i was thinking maybe the laptop h/d was the fault (as it didn't load the o/s when it was in the laptop) but surely if it was faulty the desktop pc would not have recognised it, any ideas, thanks all. oh i haven't tried any other h/d yet thought i would ask on here first.
