R9 270X 2GB OC (Gigabyte) PROBLEM
leezay
13
Hello everyone ! Today I finally bought a new PC. I installed Assassins's Creed 4 Black Flag and Skyrim. Everytime I start AC or Skyrim it's a bit laggy. (20-25fps) I don't know what's the problem. Graphic card is new. I put it inside on my own, I'm not sure but I could do something wrong when installing card so could that be problem ? Or it's just something like powersaving mode in Catalyst ? I don't know what could be problem... And card is very noisy..
My PC : MB : ASUS P8B75
CPU : i3 3220, 3.3Ghz
GPU : ...
RAM : 8GB
22 inch full hd screen..
Almost forgot, I'm using VGA to DVI reduction.. It might be with that.. Idk, but thanks even for reading this.
VGA = analogue (not very good) DVI = digital (very good).
Make sure you have the latest motherboard bios updates and have installed the latest drivers for the GPU.
the 270x with the stock cooler is always going to be noisy and kinda hot. It's just how they are made. I'm pretty sure they will run safely at up to 94 degrees, but the fan on those can get pretty loud. Your psu is fine, nothing wrong with that model for what you are using it for
So, ok. Card is installed correctly. But then what could cause frame drops ? Yesterday I played Skyrim on Intel HD Graphics 2500 (on actual computer without gpu) and it was perfectly smooth on medium settings. But even when I put everything (now) on low with FHD resolution it run just around 20-25 fps
I'm not sure what exactly happened but everything's ok right now. Card have 29 C in iddle and around 40 when playing games. I just maxed Witcher 2.. Same with Skyrim and GTA IV.. Just AC BF is soo laggy
