My monitor has dvi-d dual channel connection ( lg m208wa ). Tried to connect with stock hdmi cable through dvi-hdmi adapter, the monitor recognizes the connection, but it immediately goes into sleep mode, no picture is displayed. In bios Pci is set as primary monitor, internal graphics is disabled. I guess it should work because doth connectors are digital. Buying dvi-dvi cable is an option, but it should work fine the way it is. Need help with that.
