Ladies & gentle boys
Apologies before hand for what could potentially result in a long-ish question
I seem to have run into a bit of a issue.
Played game last night, VGA not detected this morning (one long beep, three short ones). Curiously, there is another short beep a little while later (which according to the manual, signifies either (1) VGA detected [which I doubt as the PCI-e error LED is on], (2) Quick boot is set to disabled [which it is, and if remember correctly, I use to always have a one short beep - one never gives enough attention when things are working] or (3) Keyboard not detected)
Weird thing is, the GPU blower fan either doesn't start at all, or goes balls to the wall with max RPM. I have switched PCI slots, no change, and I have popped a GTX460 into the board which worked fine. While the 460 was doing it's thing, I took the opportunity to remove all drivers with DDU (display driver uninstaller) which didn't improve anything on the r9 290 side of things. neither did taking out the CMOS battery for 10-15mins. There is also currently no overclock CPU side
I must add that a while back I had the dreaded black screen issues that alot of the R9 290* boys had, so I flashed new bios which I received from PowerColor and the problem has been sorted since. The GPU is underclocked a slight bit (for further mitigation of the black screen issues) & custom fan profiles, all via afterburner
The card's power LED's are on, so there is most defs power, card is also warm to the touch (presumably the no-fans things doesn't help an already dragon's breath warm card)
Among other things, I use the PC as a media server, and my HTPC connects to it fine, streaming shows to kodi etc etc and I can RDP into the PC without a hitch.
Honestly, the ONLY thing that has changed in the last week was that I have added two more HDD's, which has been performing fine
Specs:
Mobo: Asus P7P55D-e
CPU : i5 750 (not having onboard video is a bit@h)
PSU : Antec 900w 80+
GPU : R9 290
Mem: 8GB XMS3 1333
Any further ideas and/or recommendations would be much appreciated
Specs:
Mobo: Asus P7P55D-e
GPU : R9 290
Mem: 8GB XMS3 1333
