R9 290 Tri-X with power requirement help
so I would be just fine even with a fx8320 at 3.8ghz, 4 fans, 2 HDDs western digital 7200rpm, m5a97 le r2.2 mobo, 8gb ram 2x4,??
650W is plenty. Wattage isn't everything. The more important stat is the ampere rating on the +12V rail. Even a quality 550W PSU will suffice.
my 8320 is overcloked to 3.8 you think that would bottleneck it? and i have a fx8320 at 3.8ghz, 4 fans, 2 HDDs western digital 7200rpm, m5a97 le r2.2 mobo, 8gb ram 2x4,??
i dont plan to overclock the gpu but my fx 8320 a bit overcloked from 3.5 to 3.8, is that too much for my 650 bronze plus PSU?
