R9 290 Upgrade with AIO water cooling or RAIJINTEK Morpheus
Blaz Ferlic
7
Hi, I am planning to upgrade my r9 290 for better cooling and lower noise.
I have the ASUS direct CU version of the card, but the temperatures and especially the noise is really high. Before I had the ASUS GTX 660 Direct CU and I could never really hear the card.
I am now deciding on going with;
- ether the RAIJINTEK Morpheus with two Noctua NF F-12 fans or
- with the Cooler master nepton 140 XL + some heat sinks on the memory and an extra fan that blows on the card.
Any suggestion are appreciated.
I think the aio water cooler would provide a bit lower temperatures and would be a little bit more expensive. But I am nut sure about the noise.
Has anybody done something like that and has any tips.
Try the G10 bracket from NZXT, it seems to fit most modern GPU's. Use that with a decent single rad AIO and you will be sweet. I also have an R290 but it's a sapphire one, I am going to get that bracket and get an AIO for it 😀
