Hi Guys,
Firstly, thanks in advance for any advice/troubleshooting ideas you can offer.
Recently changed over to a new MB, RAM, CPU etc. flushed the system a few times with distilled water and then put in my new Mayhem Pastel White liquid.
The problem is as follows:
As you can see from the photos, pretty much after the CPU block, the flow stops circulating, meaning it's running really inefficiently and recycling the same liquid rather than running through the entire system/rad.
View: https://imgur.com/a/PFbFgl0
View: https://imgur.com/a/35SIfJF
After the CPU block there is liquid - although it looks like it isn't moving at all, and after the RAD there's no liquid. I knew there may be a little trapped air, but this seems more like perhaps the pump isn't strong enough or, there's a block/clogging in the CPU block/RAD.
It's also worth noting that there's a tiny little buzzing sound coming from the pump at the moment, almost like a slight vibration.
I've taken the loop pretty much mostly apart and re-assembled, tried tilting, running with the cap off/open etc. but no joy, any suggestions?
Cheers
Cheers
