Hello friends at Toms, I’m trying to OC my video card a Powercolor Radeon 5850.
Method 1: I increase the clock cycles in increments of 5 to 10 in CCC and I run Furmark after each edit then test with the heaven benchmark. When I reach a point where it fails, I reset the clock back 5 to 10 and that should be my sweet spot. Right?
Method 2: Let the “Catalyst Control Center” auto tune the card. I did this first thinking I could get near the best OC for the card then tweek it some.
The default settings are clock 760/ mem 1050.
the "Auto tune" in CCC ramps it up to 865/1215 but the card freezes.
I’ve managed to manually get up to 805/1050 and it runs stable at 810/1050 it crashes. I’m confused why the auto tune would set it so fast that it crashes.
This is the first computer I built myself and I'm kinda new to this stuff.
Thanks for your time.
AsRock x58-xtreme mobo
Intel Core i7 930 Mhz
CORSAIR DOMINATOR 6GB (3x2GB) 240-Pin SDRAM DDR3 1600 (PC3 12800) CMP6GX3M3A1600C8
CM 690 case
CM 750 watt ps
CM Hyper N520
PowerColor Radeon 5850 gpu
Asus CD ROM
M-audio Studiophile AV 40 speakers
CM 690 case
CM 750 watt ps
CM Hyper N520
Asus CD ROM
