J Jeffrey_7 Reputable Jan 3, 2016 10 0 4,510 Apr 30, 2016 #1 I have a question about the settings window. On every menu, when I click on 'additional settings' or 'advanced setup' for example, nothing happens.
Solution H H huvik Apr 30, 2016 it takes a couple seconds but a separate window should pop up. looks exactly like the old CCC
H huvik Reputable Apr 27, 2015 559 0 5,160 Apr 30, 2016 Solution #2 it takes a couple seconds but a separate window should pop up. looks exactly like the old CCC Upvote 0 Downvote Solution
