Question Radeon Rx 580 blue light but not spinning
What are the complete specs for your system (make/model of ALL installed components)?
Do you have the PCIe power cable(s) firmly attached to both the GPU and to the PSU (assuming modular cables)?
Do you have both the 8-pin and 24-pin power cables firmly attached to the motherboard and PSU?
Yes, i have everything attached.
my specs are
TEAMGROUP T-CREATE CLASSIC 10L DDR5 32GB Kit (2 x 16GB
GIGABYTE B650 AORUS ELITE AX V2
MSI MAG A850GL PCIE 5 & ATX
XFX Radeon RX 580 GTS XXX Edition
AMD Ryzen 5 7600 6-Core, 12-Thread Unlocked Desktop Processor
Silicon Power 1TB
Corsair 3000D AIRFLOW
Try connecting to the motherboard ports. The 7000 series CPU has an integrated GPU.
I totally forgot to mention that the dram light is on and i tried testing one stick one by one in each slot but it still won't turn off. i dont know if it affects the gpu but i will try what you said.
Would you be so kind and check the following:
- PSU cable to motherboard (24pin)
- PSU cable to motherboard (4 or 8 pin) - this is CPU power cable
- Remove all the memory modules and insert only one in slot 1(many mb's have this glitch)
