Alright, I have been doiing some research on graphics cards and there's 2 different types of air cooling solution for video cards today. They are either reference cards using a radial(blower) fan that directly exhaust the video card's heat out the back of the case and the nonreference axial fans that blow the video card's heat into the case.
Now, I have a corsair 600T with stock fans a H80 CPU cooler and I like my case quiet when possible, but I also love eyecandy on my games, so I plan to buy a single high end graphics card like the upcoming HD7000 series or GTX 600 series. But I have run into the problem of choosing which type of graphics card.
Pros/cons of blower type GPUs (video cards):
Pros:
1) Sucks air from inside of the case to cool the GPU and directly pushes hot air out of the case.
2) Results in lower temperaturees of other components in the case.
3) Cools GPU even if case has bad airflow
Cons:
1) Loud under load (like a jet engine).
2) Subpar cooling performance.
Pros/cons of axial fans mounted GPUs:
Pros:
1) Lower GPU temperatures
2) Lower temperatures mean higher overclocks
3) Generates less noise
Cons:
1) Blows hot air back into the case causing the other components in the to get hotter.
2) Bad for cases with bad airflow because heat keeps recirculating in case.
All these pros and cons are based off articles and topics from varous websites, if any of these pros and cons are false please let me know and explain they are wrong.
Like I said, I have a corsair 600T with stock fans a H80 running push/pull, I'm not sure which route to take, would you guys say my case has good or bad airflow? And I need advice on which type of graphics card to go for.
How much louder are blowers compared to axial fans anyways...?
Thanks for reading and replies are appreciated.
Pros:
Cons:
Pros:
Cons:
