It comes down to this: does the direction of air flow through the radiator make much or any difference
The rest is just more detailed.
I am stumped and was hoping for some feedback. Building my second build. I have a Corsair Crystal 570X case w a Corsair H100i Platinum RGB radiator system. I had an H100 in my first build that was positioned at the top of my Corsair 600T case. It worked well and I had Static Pressure fans at the top w the radiator beneath it. The fans were pushing air straight down to the radiator This arrangement lasted five years w/o at single problem.
Now working on new build. I have two 140mm at the top of my case which I purchased separately. I still have the two 120mm Corsair fans that come w the H100i.
The 140mm fans on pulling air into the unit. I am debating now as whether I could fit the H100i radiator at the top of the inside case unit.
Now, as a side note the sales guy suggested mounting the radiator in a vertical position. So not sure how to proceed.
