Radiator Front intake or exuast?
RAY_100
11
my setup is
I7 870 Currently Overclocked at 3.7ghz
AMD Radeon RX470 4G Open Air type GPU
And case With bottom intake installed and only front side radiator support
currently i installed radiator as exuast to front but case fan is exuating to back
is this bad air flow?
Yes, Exhaust should vent out the topmost part of your case. Warm/hot air rises above cooler air.
So intake from the front/bottom, exhaust out the top/back
thanks i've change radiator as intake by just install radi fan in front
should these aio cooler fan work as intake?
It is entirely up to you, but if you can put the AIO radiator in the front, I advise you do that.
