RAID 6 and hot swap
NdridCold
25
If you have 2 drives fail in a RAID 6 setup with 6 physical drives can you hot swap them out at the same time or do you have to rebuild the array one drive at a time?
Yes, it can be done.
If you have a drive that is acting up, replace it and let it rebuild. The whole thing with raid, is that it is high availability(of the data) - you shouldn't have to power down(and remove access to data) because of a single disk problem.
But theoretically it can be done?
Also have another question. Little different scenario. Still have a RAID 6 but only one failed drive with another showing signs of failure, so:
PD1= Failed Firmware State
PD2- Media errors but not in a failed firmware state
Question is would PD2, if hot swapped be rebuilt from parity even though its technically not a failed drive or if I want to replace that drive would I need to shut down the server, clone the drive and stick it back in? Or just wait until it completely goes belly up then swap it out?
Ok. That answers my question. I was just not clear on if a drive needs to be in a certain state in order to trigger the parity rebuild if you put another (new) drive in. Thanks!
DO NOT attempt to rebuild a RAID 6 array with a drive that has media errors included.
It WILL cause inconsistent parity problems.
Assuming you have a backup, you have 2 safe options.
1. Remove both unstable drives and rebuild 1 at a time to 2 spares.
2. Remove both unstable drives, get a 100% sector by sector image from the drive with media errors on to a spare, then replace both drives to do a rebuild.
If you DON'T have a independent dedicated backup, then you have 1 safe option:
Remove all drives and make sector by sector images and then proceed to the above steps for rebuild.
Unless you remove both unstable/failed drives you have little assurance that the rebuild won't occur without outdated/corrupt parity data from the drive with media errors.
The safe option is to rebuild 1 at a time.
