I have recently installed a software called Rainmeter. Rainmeter is a tool for customizing the look and feel of your pc. The software is based on community skins that are free to download. By downloading these skins you can get a really sleek and nice looking desktop.
I am having a technical problem with a skin called honeycomb. This skin creates custom clickable icons for your desktop. These are run by something that looks alot like what you would find in batch files. My problem is that the files are not executing exe files in certain directories. I know my path is correct and the same is working for others.
Im including some screencaps of what the icons look like, a batch file that works and one that doesnt.
My operating system is windows 10.
Thank you all in advance
Icons:
https://drive.google.com/open?id=0BzCjFK7pTjhrdVVoOHV1ak5RVk0
File that works:
https://drive.google.com/open?id=0BzCjFK7pTjhrRzIwb3FNbEFhZ1k
File that doesnt work:
https://drive.google.com/open?id=0BzCjFK7pTjhra19WaEtBdWxFRVk
Icons:
File that works:
