Question RAM is not running at the advertised XMP timings/speed ?
NathW90
66
Hi all,
Today my new RAM arrived and upon installing, the PC simply lights up for 3-5 seconds, before everything switches off again and then the cycle just continuously repeats. When I put my old RAM in - as I have now - the PC is back to working just fine.
My current RAM is HyperX Fury RGB DDR4 3733mt/s 2 x 8GB and the new RAM I'm trying to install is Kingston Fury Beast RGB DDR4 3733mt/s 2 x 16GB. My PC is a HP Omen using the Intel Z690 chipset with their BlizzardOC 8917 board, and I'm on the latest BIOS. I can't see any reason why the new RAM wouldn't be compatible or cause a problem. It's essentially a like for like swap, just more memory.
I've tried both new stick in slots 2 and 4 together, both in slot 2 separately and both in slot 4 separately, and it's the exact same issue every time.
EDIT:
Apologies, this specific issue is now resolved. It was overclocking being enabled in Omen Gaming Hub causing the issue. Once I switched that off, it worked and the PC boots as it should.
That said, I do have another related issue I've now noticed. Please see this post:
https://forums.tomshardware.com/threads/new-ram-causing-restarts.3855962/#post-23342427
if you try manual ........... 3733 CL19-23-23 @ 1.35V but I don't think let you do it
Does this look safe to try? All the 0's are AUTO, the 12 and 24 and NMode and Gear Ratio and Memory Voltage are all the same as the XMP profiles.
