[SOLVED] RAM placement for newbie !!! Help me please :)
14
Hello guys!!! I have single 8GB 2666Mhz ram right now in my pc and im thinking to upgrade it from 8GB to 16GB. I have heard before that dual 8GB 2666Mhz gives better performance compared to single 16GB 2666Mhz. So i bought dual 8GB 2666Mhz ram. My question is, where should i stick my ram into my motherboard to gives the best performance it can gives? My motherboard is B360M AORUS GAMING 3 (rev. 1.0) and it is Dual channel memory architecture ... I know it sounds silly but i need to know the best placement of ram in my motherboard for the best performance since it can stick up to 4 ram sticks in it... Here is the picture of DDR4 ram placement in my motherboard --- View: https://imgur.com/a/gxNThad
EZ!!! Place it in the slots closest to the left. There is not really a difference on where you place it but the general rule for gpus are closest to the top and for ram it is the closest to the left.
