Am I reading that right 8Gb of main system memory.
Available physical memory 82.0 MB.
With 96% memory utilization.
You have a few things running there on startup I would say.
By look of it a lot of programs set to auto run after windows has loaded.
Go to your start bar, click on it.
In your search box type: msconfig, and press enter.
Click on the start up tab on the new box that opens.
In there is a list of all the programs set to auto load and run after windows os.
Un tick them, and click ok or apply.
Restart your computer, let it load up and check how much available free memory you have then and see if your memory utilization has lowered.
Is windows slow to respond when you click on things ?
If it is it`s because you have loads of programs wanting to auto run, each one is stealing system ram.
[/quotemsg]
This is it normally , about 10 minutes after start up.
