Hello, I'm just a quick note that I built my pc and kinda new regarding pc hardware.
I have been using my PC for almost a year now and recently had this problem where my ram's only using 8gb instead of 16gb and its speed suddenly went from 3200 to 2133 MHz.
I don't know when this problem started but I have a guess when it did. It probably started when I recently cleaned my pc using a vacuum cleaner set to blow.
After I re-plugged all the wires to my pc (monitor, mouse, etc), I booted it up the lights turned on then off then it turned on again and off, and it repeated again then it booted up properly.
After that event, the next time I booted up my pc it has a significant delay where I press the switch, light turns on, but it takes time for the peripherals to light up. Unlike before it was cleaned up, it boots up instantaneously. This also happens when I exit bios.
I have went to the bios and I can not find where I could adjust the ram frequency and timing, although I didn't have any problem setting it when I first configured it.
My bios is has not been manually updated since I built my pc.
I have seen a thread where you could set the maximum memory in BOOT Advanced option. I haven't tried but it seemed to work on the person on the thread. I haven't done this because I wanted also my ram speed to be 3200MHz.
tldr: 16gb ram 8gb usable, ram frequency went down from 3200MHz to 2133MHz, and PC delay in turning on.
I'm really sorry if my explanations are messy. I'm currently typing this really late at night.
CPU-Z SPD Tab:
CPUZ Memory Tab:
Task Manager:
System:
NZXT CAM:
CAM's cpu timing is 15-15-15-36 but when I checked the bios it's 16-18-18-36.
Specs:
Msi B350 Mortar
GTX 1070
Ryzen 5 1600x
Corsair 8x2 DDR4 3200MHz
Windows 10 Pro
CPU-Z SPD Tab:
CPUZ Memory Tab:
Task Manager:
System:
NZXT CAM:
Specs:
Msi B350 Mortar
GTX 1070
Ryzen 5 1600x
Windows 10 Pro
