hello , i have a z68 extreme 3 gen 3 motherboard that i bought a little over a year ago , few months ago i was trying to clean the motherboard and put new thermal paste when i tried to mount back my cpu cooler i mounted it the wrong way which made it a little overtight on the cpu but i corrected it when i tried to boot up my pc i got an error 55 ,after trying different ram slots i found out that my a1 and a2 slots are no longer working so i just kept on using single channel untill recently i wanted to try the broken slot again and i got smoke comming from the mb near the ram slots i unplugged as fast as possible it tuns out that on of the transistors on my mb was fried ...at the moment the motherboard works for surfing net nad watching stuff but if i game on it i get rashes and memory errors , i took it to a local shop to get fixed and he told me that he cant find out what transistor is that bc u cant see the reference on it and that i had either to find a scheme of the motherboard that i contacted asrock for but no reply or get a similar mb so he can check it and i couldnt find any , can you help me if you have any knowledge about this or check for me if you have the same motherboard....the transistor s code or however its called on the motherboard is Q7505 its located on the top right of the motherboard near the 2 capacitors
