RAM slots and sticks OK, but still not showing! HELP! :-(
Christian_87
Commendable
Feb 17, 2016
4
I recently bought 2 new sticks of Corsair 4GB CML8GX3M2A1600C9 for my ASUS Maximus V GENE Motherboard, however they don't seem to want to play together with my already installed 2 x 4GB Corsair Vengeance CMZ8GX3M2A1600C8R sticks as they only work separately but not mixed in various slot configs. PLEASE HELP! I suspect it may be a BIOS setting/s.
Cheers!
I suspect the sticks just don't want to play. It's never a good idea to mix packages of DRAM, there are no guarantees they will play nice, even if both sets are the same exact model. Try adding about + 0.06 to the DRAM voltage and then add the second set and see if that does it, if not we can try a little extra to the MC (memory controller) voltage
Thanks Tradesman1, I had a little play with the voltages, unfortunately no luck. lesson learned I guess 🙁 might you be able to suggest a 16gb kit that would work? THERE ARE SO MANY! :??: Thanks again for your help :)
PC Specs.
Asus ROG Maximus V Gene
Intel i7 2700K
