Should you spend is up to you and your budget, but if you do please check the Support page for your motherboard for set compatibility before buying any set.Hello guys,
I bought B760 Gaming X AX motherboard and i5-12400f CPU.
Should i spend money on 16GB 6400MHz CL32? Will it work with 6400MHz?
I have a budget and the motherboard supports up to 7600MHz. But my question is will it work on 6400MHz with i5-12400 CPU or i shouldn't spend money.Should you spend is up to you and your budget, but if you do please check the Support page for your motherboard for set compatibility before buying any set.
You need to look up the specific memory model number to determine your compatibility, but yes any board that supports up to 7600MHz will support the very common 6400 MHz speed as a general matter.I have a budget and the motherboard supports up to 7600MHz. But my question is will it work on 6400MHz with i5-12400 CPU or i shouldn't spend money.
Should you buy 6400 ram?... Probably not if it is more expensive.Hello guys,
