Question Ram speed question
smalltech
645
5
18,995
Hi,
If I use this ram 840006618676 CORSAIR VENGEANCE LPX 3600MHz 32GB CL18
In Asus UEFI BIOS, I see the screenshot below, I see 2133MHz.
Do I need to change anything in the screenshot (all settings are defaults)? If yes, how to change?
I did not change anything in the BIOS, I am not sure if I need to do something in the BIOS to get 3600MHz, I am worried I may do something that would corrupt my Windows 10 PC or BIOS or make it unstable.
Thanks
View: https://i.imgur.com/2mLGoJq.png
2133mhz is the default speed for ddr4, You just need to load the XMP profiles for the ram to work at its rated speed.
How to do it correctly?
I read some people have BSOD or weird problems after enable XMP in the threads below, I want to make sure I do it correctly without any problem.
