M Moholeo Commendable Apr 6, 2016 6 0 1,510 Apr 15, 2016 #1 Is it worth spending £30 for higher Mhz? Is it worth upgrading to 16gb for more? i5 2500k (@4.2Ghz) P8P67 mobo 8Gb 1333 Mhz RAM Asus GTX 770 Directcuii 2Gb Should I not bother?
Solution geofelt Apr 15, 2016 If your main purpose is gaming and not heavy multitasking, 8gb is fine and not worth replacing. Sandy bridge does not benefit much from fast ram. Here is a report on ram speed scaling: http://www.anandtech.com/show/4503/sandy-bridge-memory-scaling-choosing-the-best-ddr3 On balance, I think more ram trumps faster ram. Spend your £30 elsewhere. If you do not already have a ssd, that is a very good performance upgrade. (not for £30 though)
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Apr 15, 2016 #2 Depends on what you do with the rig, higher data rate DRAM or more DRAM can be handy especially if using data intensive apps or multi-tasking a fair amount 😉 Upvote 0 Downvote
geofelt Titan Oct 9, 2006 56,052 4,859 174,240 Apr 15, 2016 Solution #3 If your main purpose is gaming and not heavy multitasking, 8gb is fine and not worth replacing. Sandy bridge does not benefit much from fast ram. Here is a report on ram speed scaling: http://www.anandtech.com/show/4503/sandy-bridge-memory-scaling-choosing-the-best-ddr3 On balance, I think more ram trumps faster ram. Spend your £30 elsewhere. If you do not already have a ssd, that is a very good performance upgrade. (not for £30 though) Upvote 1 Downvote Solution
